I pulled all of the fairings/bodywork off my Paso...
Posted: Sun Mar 03, 2013 6:08 pm
I bought my Paso last May with the idea of flipping it, but I have kind of fallen under the Paso spell. Yesterday, I decided to pull off all of the plastic bodywork to check out what is sitting underneath it. (Getting those oil coolers out was kind of like pulling teeth......)
I found that it has had the Dell Orto carb conversion done to it, but other than that it all looks like it's in pretty stock condition. There is one question I have, though:
What is the little black plastic chamber at the back of the motor, mounted right under where the front of the seat and the rear of the fuel tank meet? It has a couple of hoses coming out of it and one goes into the motor and the other looks like it vents toward the rear, left hand side of the bike..?? The hoses on mine are all cracked and leaking. (I assume it's like a PCV valve/system on a car.) Can I get rid of the box and just put a filter on the end of the hose that comes out of the engine??
Thanks,
Jason.
PS. I want to change the oil but the Nearest Ducati dealer is about 35 miles away. What is the best way to get hold of the correct oil filter?? And which oil do you guys recommend?
Thanks,
Jason.
