Where ??????????????
Posted: Wed Mar 27, 2013 3:12 am
by kettlep
Hi everyone ---- I am a new guy to DUCATIPASO.ORG and am totally lost!
Over 20 years ago I was the very proud owner of a 900SS and loved it dearly.
Now I am the proud owner of a 1987 - 750 Paso with 28K miles, which I purchased on Saturday.
However - I have now really looked at the bike and identified I need new tires, new rotors and new timing belts, but I cannot find any anywhere?
My question is how do you guys ride your bikes or did you accumulate parts over the years to maintain your bikes.
The PASO is a beautiful bike and I am hoping one day to again be a proud owner and have it on the road enjoying a "Duke" again.
Any help will be greatly appreciated and I hope I am in the correct area of the site for these questions.
Thanks,
Peter.
Re: Where ??????????????
Posted: Wed Mar 27, 2013 6:10 am
by ducinthebay
Peter,
Welcome to the site, and remember, all who wander are not necessarily lost.
Of course the short answer to your lead question is simply - HERE!
There is a SEARCH button on the grey banner above. Click on that and all will be made clear as mud. You will have more answers to life's eternal questions than you care to read before bedtime. At least 47 opinions on tires, 27 ways to tension your belts, and at least a dozen opinions on mirrors.
Re: Where ??
Posted: Thu Mar 28, 2013 7:03 pm
by 20YearOwner
Welcome New Ducati Paso Owner!
New tires are available from several sources, new timing belts are avaialble from Ducati, new rotors could be a small problem, try used first from ebay or other etc. if that does not work, email me I can help you search.
Regards,
Posted: Thu Mar 28, 2013 11:41 pm
by bmw851
Posted: Fri Mar 29, 2013 2:09 pm
by jfiore
www.bevelheaven.com is a good source for a variety of gasket kits, master cylinder rebuild kits, brake calipers, master cylinders, timing belts, etc.
They stock quite a few parts for the Pantah vintage bikes, including the Paso (especially the 750).
Thay don't have OEM brake rotors, but they sell full-floating replacement rotors that will fit the Paso.
Posted: Fri Mar 29, 2013 3:29 pm
by randtcastell
Can you say "Ebay"? a special vendor there, 'guzzitech' has many many Pasos and probably has parts you need in fairly decent shape ready for refurbishment. Welcome and congratulations on your choice of Duc. Your choice of the Paso is indicative of your discerning nature and high aesthic ideals. They are brilliant. They are sickness.
Posted: Thu Apr 04, 2013 4:22 am
by Desmo_Demon
kettlep wrote:I need new tires, new rotors
Unless the rotors are warped, I've never seen any Paso rotors that were worn thin enough to need replacing. They may only need to be cleaned and repainted/refinished.
Posted: Thu Apr 04, 2013 6:42 am
by Skins
Because the original cast rotors are nice and thick, it is possible to have them machined flat if they are not too badly warped. I had mine machined when they developed a slight warp.
Can't remember whether I has one or both done - it was a few years ago.
