Page 1 of 2
WTB Tachometer cable for 907ie.
Posted: Sun Mar 31, 2013 1:01 pm
by st2sam
Tachometer cable for 907ie needed. I found a new one for sale here but the member has not been on line for two years...
Would cables for a different model fit?
Any help would be appreciated, thanks...
Re: WTB Tachometer cable for 907ie.
Posted: Sun Mar 31, 2013 3:39 pm
by Derek
I needed a replacement and found they are no longer available from Ducati so I fitted one from a 900SS. It is about 100mm longer but the excess length is lost behind the headlamp and it works just fine.
They are still available from Stein Dinse;
http://www.stein-dinse.biz/Ducati/Searc ... 10417.html
Posted: Sun Mar 31, 2013 4:36 pm
by persempre907
The 750 cable is too short for the 907.
If you don't manage to find a 907 one, buy a SS one.
Posted: Sun Mar 31, 2013 10:02 pm
by st2sam
Thanks for the quick response guys.
Also, thanks for the link Derek but ordering from the UK is a last resort.
If anyone else has idea's, or one for sale, please chime in.
I wonder if it's possible to just replace the inner piece, as the outside cover is in good shape?
Has anyone tried this ?
Posted: Sun Mar 31, 2013 11:42 pm
by Tamburinifan
Yes. Quite easy to do.
Posted: Mon Apr 01, 2013 10:30 pm
by englishstiv
Give these guys an email
http://www.carrotcycles.co.uk/custom-ma ... fo_10.html
If enough people are interested we could get a batch made up I am happy to send them original pattern one to work off.
You could even make your own using their supplied parts.
Posted: Tue Apr 02, 2013 2:24 am
by st2sam
englishstiv wrote:Give these guys an email
Thanks englishstiv.
If all else fails and I can't find a replacement in the States I'll e-mail these guys....
Posted: Fri Apr 05, 2013 11:31 am
by st2sam
I'm going to try and solder it this weekend, I'll post my results.
If anyone has one for sale (in the States) I would much rather replace than repair.
thanks, Sam...
Posted: Fri Apr 05, 2013 1:39 pm
by Tamburinifan
Reading the 907 forum ("Breaking in UK) can be rewarding
http://item.mobileweb.ebay.co.uk/viewit ... 6412447503
Posted: Fri Apr 05, 2013 2:33 pm
by Derek
A new 900SS tacho cable cost me £24.28 from my local dealer.
Posted: Fri Apr 05, 2013 11:57 pm
by Duc750
Venhill in the UK will also make them - they need a pattern though but once they have the pattern can make to order - if I can get down to Surrey before i put the engine back in mine they can use my speedo, Tacho and throttle cables as patterns.
Also talking to someone about making a new coolant reservoir and chain sliders !
Coolant res I have as a spare for a pattern but I could do with a good condition or new old stock chain slider if we get to that point.
Posted: Sat Apr 06, 2013 1:45 am
by st2sam
Duc750 wrote:Venhill in the UK will also make them - they need a pattern though but once they have the pattern can make to order - if I can get down to Surrey before i put the engine back in mine they can use my speedo, Tacho and throttle cables as patterns.
Also talking to someone about making a new coolant reservoir and chain sliders !.
AWESOME!
A member PM'ed me and has a cable from a 906 Paso that he'll sell. I hope they are the same as the 907ie, we'll see....
Posted: Sun Apr 07, 2013 12:44 pm
by st2sam
Derek wrote:I needed a replacement and found they are no longer available from Ducati so I fitted one from a 900SS. It is about 100mm longer but the excess length is lost behind the headlamp and it works just fine.
Derek wrote:A new 900SS tacho cable cost me £24.28 from my local dealer.
I can get a tachometer cable, here in the States, for a 1997 900ss. (new)
Can you guys tell me what year 900ss your cable is from? Does it matter?
Thanks, Sam.
Posted: Mon Apr 08, 2013 8:58 am
by Derek
st2sam wrote:Derek wrote:I needed a replacement and found they are no longer available from Ducati so I fitted one from a 900SS. It is about 100mm longer but the excess length is lost behind the headlamp and it works just fine.
Thanks, Sam.
A cable from any carbed 750/900SS from '92 to '97 should fit. Part no. is 0670.38.720
I didn't realise that the 750 Paso cable was shorter. I guess it's because it doesn't have to clear the radiator and has more direct route.
Posted: Mon Apr 08, 2013 11:36 am
by st2sam
[/quote]
I didn't realise that the 750 Paso cable was shorter. I guess it's because it doesn't have to clear the radiator and has more direct route.[/quote]
Awesome, and thanks again Derek (and all that responded) for taking the time and posting the part number.
That is the part number I was given, it's for a 1997 900ss, I'll order it later today from my local Ducati dealer.
Oh, I did try to repair my cable with solder, then epoxy. No way in hell.
You gotta replace it.............
