3d chain slider
Posted: Thu Apr 04, 2013 12:26 am
by plasmid
Re: 3d chain slider
Posted: Thu Apr 04, 2013 12:37 am
by ahdoman
I've got two friends who do that. All I need are CAD's and I could get a quote.
Re: 3d chain slider
Posted: Thu Apr 04, 2013 7:13 pm
by englishstiv
I am looking for two to replace I have one reasonably good one for spec'
Interested in purchasing two if any are made
Re: 3d chain slider
Posted: Fri Apr 05, 2013 7:38 am
by Mc tool
If you are going to get some made there are at least 2 different ones. The one on the top is a new spare part bought a few years ago and the other is of an older p750. the differences are the extra lug near the pivot end and the "nose" of the new one has been flattened off where it goes round the front of the swing arm , and the brass nut is not fully moulded into the new guide
Hamish
Re: 3d chain slider
Posted: Fri Apr 05, 2013 1:46 pm
by plasmid
Hamish
Was referring to the small one that fits on the center stand -
http://www.stein-dinse.biz/Complete-par ... :2494.html
The big one would probably be $100+ to print via shapeways.
Personally, only know one person that could maybe make the 3d model - waiting on confirmation.
Re: 3d chain slider
Posted: Fri Apr 05, 2013 11:59 pm
by Duc750
I'm also talking to someone about making these so we'll compare notes.
Re: 3d chain slider
Posted: Sat Apr 06, 2013 1:07 am
by plasmid
Duc750 wrote:I'm also talking to someone about making these so we'll compare notes.
Do you have a CAD model already?
No point in duplicating if you already do.
Re: 3d chain slider
Posted: Sat Apr 06, 2013 1:57 am
by Mc tool
Hamish
Ah ! you got me there , mine never had a centre stand ( till I made one .... really for workshop purposes only) , But I did make one for the frame out of a bit of nylon ( actually a bit of Dianne's kitchen cutting board......chopped right out of the middle too, just to be sure she would notice and praise my resourcefulness...... didn't work
Re: 3d chain slider
Posted: Sat Apr 06, 2013 7:45 am
by Duc750
Not yet he's prepeared to scan it to create the model though so that's easy. He does some work with local universiies so trying to see if he can get mold costs covered as part of a student project etc.
Money first, CAD later!
Re: 3d chain slider
Posted: Sat Apr 06, 2013 9:45 am
by plasmid
Duc750 wrote:Duc750 wrote:I'm also talking to someone about making these so we'll compare notes.
Hm, ask him to submit the model to shapeways and then anyone can get it made pronto.
http://www.shapeways.com/about/how_does ... -learnmore
Re: 3d chain slider
Posted: Sat Apr 06, 2013 10:30 am
by Duc750
True, we can get it printed in quite a few places. We could also get one carved out of dried sheep poo, chiselled from granite or cnc from billet. All of which will be the same amount of use unless the material is right for the application. Materials for 3d printing aren't exactly main stream and the sort of nylon delrin mix that a chain slider should be is really quite difficult to print.
The guy I'm talking to runs an automotive component manufacturer. Some of the components he makes are chain sliders so he already has material specs to use from some other manufacturers. He's also planning to expolore 3d with this but is not hopefully for getting a long lasting product with standard techniques. This may not be a quick solution but it could be an enduring one if it works out right.
Re: 3d chain slider
Posted: Sat Apr 06, 2013 1:30 pm
by plasmid
Duc750 wrote:True, we can get it printed in quite a few places. We could also get one carved out of dried sheep poo, chiselled from granite or cnc from billet. All of which will be the same amount of use unless the material is right for the application. Materials for 3d printing aren't exactly main stream and the sort of nylon delrin mix that a chain slider should be is really quite difficult to print.
Alright. Sounds good.
