coil mounting
Posted: Sat Apr 20, 2013 2:48 pm
Hello everyone,
I am back at it again, trying to make my Paso more reliable and failing miserably
I was taking off the rear cylinder coil to clean the ground and the one bolt snapped on its way out. I drilled and tried the trusted easy out,which snapped.
I tried drilling the easy out,with no luck.
Where are you fellow Paso owners mounting the coil at where you get a good ground with little effort? (ie-drilling into frame?
Thanks a ton and keep the rubber side down!
Rich
Rich
