Which UK grade of brake fluid should I use??
Posted: Sat Jun 08, 2013 10:39 am
by Graemer57
I need to replace the brake fluid in my 750 Paso but am not sure which brake fluid to use Dot3, Dot4 Dot??? Anyone got advice. Did a very quick search but couldnt see anything
Graeme
Re: Which UK grade of brake fluid should I use??
Posted: Sat Jun 08, 2013 11:37 am
by 907pasonut
hi Graeme, I've used Castrol Dot 4 without any problems, some are less prone to moisture contamination...not sure which.
Posted: Sat Jun 08, 2013 12:02 pm
use DOT4. It`s boiling point is higher.
Also if you look in the owner`s manual it says to use DOT4
Posted: Sat Jun 08, 2013 4:24 pm
by ducinthebay
Don't use DOT 5. It is not compatible with a system that has use DOT 3 and 4.
Posted: Sat Jun 08, 2013 8:16 pm
by Graemer57
Thanks for the help Dot4 it is then!
Graeme
