Valve adjustement
Posted: Sun Jun 09, 2013 2:49 pm
When I re-activated my Paso my mechanic was already retired. Therefore I decided to do the necessary work by myself.
Actually I don’t have the necessary equipment to adjust the valves by myself. But at least I checked them to see whether there is something to do. So I gathered all the necessary Infos and Tools to check the valves.
The Result of that you see below.
For those (I guess most of you) which are not fluent in German some translations below
Einlass = intake
Auslass = outlet
Öffner = opener
Schliesser = close
The admissible tolerances you find on my check-sheet below
First of all my general Interpretation is as follows:
-With time the gap of the opener is decreasing
-With time the gap of the closer is increasing
So if you check the gaps which I measured on my 750 my interpretation of the situation is as follows:
Front cylinder opener/outlet: with 0.15 slightly outside tolerance, but as with time the gap decreases no real necessity to change something
Standing cylinder closer intaket: with 0.07 outside tolerance, should probably be adjusted.
I went to a mechanic to ask the question whether there is an urge necessity to do something. I just got the (stupid?) answer that it has to be inside the tolerances, that’s why they put the tolerances.
I just ask myself whether it does any harm to the head/engine if the gaps are a bit (max 0.05) higer?
I’ve heard that on new Ducatis the tolerances are bigger, to decrease the service intervals.
So if any of you guys has experience with valve adjustments please let me know your opinion
pasoalf
Einlass = intake
Auslass = outlet
Öffner = opener
Schliesser = close
pasoalf
