Is there a difference between 160/60 ZR16 and a 160/60 ZR17.
What air pressure do I need to put in the rear suspension.
Rear Tyre and Suspension
20YearOwner
Re: Rear Tyre and Suspension
The answer to your question is somewhat dependant on the weight you plan to carry, i.e. if you have a passenger etc. Try a range from 36 PSI to 38 PSI and see how it works.
and yes one is a 16 inch tire one is a 17 very different indeed
