Right side mirror needed
docbob
Yes, a mishap destroyed the right side mirror on my 907ie. Anyone know how to locate one?
Bob--docbob1@msn.com
Re: Right side mirror needed
There are mirror/ blinker assy's ( new ) on E-bay , unpainted , either single or in pairs ( that's pairs of mirrors .... not tits or sheep
) and there are also 2nd hand ones too
- ducbertus
Hi Bob,
sorry to hear you cracked a mirror.
try Ebay or Far in Italy. they produce replica's which will do the job.
Bertus
Bertus
docbob
Thanks guys,
Unfortunately, my mirror is the one with the little clips rather than the studss. They are very difficult to come by.
fortunately some one has made this handy adaptor..... which comes with every Paso:)
Ditto for your 906 and 750 posts
121144410034 is the # for the E-bay listing
- englishstiv
US $300.00 !!!!!!! plus postage ????
McTool the cost of those Far mirrors is obscene they must only cost about $52 (US) each to buy direct, sadly though you have to buy them in numbers of 25 plus.
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
Yeah ! I want a spare set .... but not that bad , still I spose if you gotta have them you would have to cough up, me ... Im eyeing E-bay daily so I you want some you will have to be quicker than me
. I have seen pix of Paso's where some one has grafted other mirrors/blinkers onto them but I really cant see the point as IMHO they are as fundamental to the Paso as the square frame and the fully enclosing body work, 16's and that weber , I guess if its your only transport needs must. And how badly damaged would they have to be before you couldn't repair them
Now that's broken , but still fixable
- ducbertus
I got a set of FAR -mirrors directly out of Italian factory in grey primer for € 82 a pair incl. posting/packaging and stuff like that. and once in colour and mounted you have to look closely to see the difference.
yes, the orginal ones with the mounting plate are better in many details. but they become scarce.
I have bought some battered original sets to repair one day. because the mirrors are one of the distinctive PASO parts.
Bertus
Bertus
muxey
Hi I have a pair in blue bit scratched on the paint, and 1 more not sure if its right or left.
E Mail duck450scr@hotmail.com
- ducbertus
Hi McTool,
your leg was definitely broken. did it heel well in such way that you got the most important functionality back?
more or less my mirror looks the same, but still I think it's fixable.
- (45.48 KiB) Downloaded 604 times
That mirror is a challenge but I bet you could fix it ... just like a jigsaw . I think the thing to do is find the correct adhesive as not all types will work on some plastics , I would go for a polyester rather than epoxy for that .
Leg? nah , 4 years on and Im still having bone grafts that don't quite work , still on crutches , and the orthopaedic guy keeps talkin amputation , I also crushed my foot , ripped my knee apart , busted my hip & pelvis and buggered my sciatic nerve so at its best possible its never going to be great
we have a glue here in the states called rapid fix
It is a form of superglue and comes with a powdered form of activator
Works on all kinds of plastic as well as lots of other materials and is sandable once dry
http://www.rapid-fix.com/
I bet it even works on bone
- englishstiv
RapidFix is the only product that can repair windshield wiper bottles over flow tanks and air intake systems. Rapidfix can also repair, gas tanks, radiators, headlight housings and can be used for electrical wiring. Unlike all other instant adhesives RapidFix has a special formula and will not dry out in the bottle. RapidFix Saves time, Saves money and is absolutely amazing.
Now that looks interesting
higgy if they won't post to over here would you be able to source a couple of marine packs for me and post to UK if I settle with you via paypal?
UPDATE >>>>>>>>THEY DO INTERNATIONAL
DUCATI 907ie 1992
Polyester resin works just fine. I did fix a couple of mirrors in the past with it.
yes polyester works,much harder to sand and takes longer to cure
Rapidfix is very fast and easily shaped and sanded or machined or whatever
I have found on washer bottles that some forms of washer solvent specifically the bug remover variety will in a week or two dissolve it...not sure why
