fuel pump / water mod.
Posted: Tue Aug 27, 2013 2:54 pm
hi there, my 906 is ready!!!
still naked because I need to check if everything is ok
but it sounds good!!
I have ready the water line mod. (with cbr600f cap) I must do that immediately to prevent tie cracking of the water tank? or I can ride it and wait....the water disaster.....
I can see on the engine and frame signs of water corrosion...and battery acid too....
do you know if there is some other caps that works great for this conversion?
I would like to buy a replacement for the fuel pump. do you know if there is one that can works fine without large mod. ?
ciao
ciao
