300 to 320mm adapters?
Someone selling any adapters f using 320mm discs on the 907?
- ducinthebay
Re: 300 to 320mm adapters?
Don't think I've ever seen those.
nope already checked...
I ended having a set custom made by DISCACCIATI - Italy (full floating cast iron).
- ducinthebay
The other way is to get some 1993 907 fork legs that came with the 320 mm rotors. Did the 1989(1990?) 851 have 320 rotors? They had M1R forks, and 17" wheels for one year.
The 851 with 17" rims had 320 mm rotors.ducinthebay wrote:The other way is to get some 1993 907 fork legs that came with the 320 mm rotors. Did the 1989(1990?) 851 have 320 rotors? They had M1R forks, and 17" wheels for one year.
- ducbertus
but the total lenght of the 851/M1R is shorter as in the 907.
Bertus
Bertus
- ducinthebay
Yes, the 851 forks are shorter, and shorter travel. But if you get just the lower fork legs, they will fit on your existing forks.
Phil
Phil
