UNSAFE!!!
Posted: Fri Oct 18, 2013 12:45 pm
I just had to ride the $350 paso before it got cold....
Now that its getting cold it's getting torn apart to reseal the engine rebuild the forks, fix the body work, reseal the calipers, etc.
the fork clamp bolts were not even close to finger tight on the right side.
the chain is so stiff i can use it to form a coat hanger.
front sprocket is wobbling its way off the shaft.
regulator wires are rotted and almost touching each other.
there are hot wires hanging open all over the bike.
it seems like absolutely everything on this bike had been messed with by a total amateur and assembled incorrectly.
i will post some pictures this weekend.
anybody know where to get piston rings?
I will be making a want list this weekend for things i need to get it all safe and back together before it starts to warm up again.
