lockable gas cap in the Netherlands
Posted: Sun Oct 20, 2013 8:40 am
by paso750
http://www.marktplaats.nl/a/motoren/ond ... ousPage=lr
it does not fit on the 907ie as the hole diameter is different.
Re: lockable gas cap in the Netherlands
Posted: Sun Oct 20, 2013 7:56 pm
by persempre907
paso750 wrote:it does not fit on the 907ie as the hole diameter is different.
Are you sure G.?
I have got the same one on my red 907.
Really, my black 907 has a different cap (same key of the ignition switch).
Posted: Mon Oct 21, 2013 7:40 am
by paso750
really, there are two different ones on the 907ie ?
750/906
outer diameter flange 120 mm
hole circle flange 102 mm
gascap 76mm
907ie
hole circle flange 110 mm
gascap ?mm
Posted: Fri Jan 17, 2014 6:30 pm
by paso750
Posted: Sat Jan 18, 2014 7:44 am
by persempre907
paso750 wrote:really, there are two different ones on the 907ie ?
750/906
gascap 76mm
907ie
gascap ?mm
It's so. My earlier 907 has the same cap of the 750/906.
The later '92's 907 has a larger cap.
