907 front wheel compatibility
Posted: Sat Dec 21, 2013 11:37 pm
by angelix
I am after an additional set of wheels for my 907, I already have the rear one but I am still missing the front.
I am looking online and there are several options available, from old 600-750-900SS with the same shape of the "spokes", but with a different part number 501.2.014.1.A
The original 907 part# is 501.2.004.1.A
Somehow I have the feeling they are exactly the same (probably a different supplier) but before committing to the purchase I wanted to verify my assumptions.
Does anybody know? :phone: :smoke: :) :)
Re: 907 front wheel compatibility
Posted: Sun Dec 22, 2013 4:51 am
by Mc tool
The wheel I have , I only suspect its from a 907 or 851 , has a different speedo drive set up than the 97 SS I had , so that could be the diff ..... not a biggie but still more $$$$$
Posted: Sun Dec 22, 2013 9:35 am
by 900streetfighter
I have spare 907 front wheel for sale. I'm in Essex. £75 + pp.
Posted: Sun Dec 22, 2013 10:39 am
Angelix, it takes a bit of detective work to find out the difference but anyone can figure it out.
The white rims were only on the 907ie, '89-91 851 and almost all '90-92 SSs.
If you check the parts catalogues you see the part number of the rim includes the bearings and bearing spacer.
If you then compare the front axle, bearing and bearing spacer part number you`ll notice they are the same for the 907ie and 851 but not the 900SS. Continue the research by googling the bearing part numbers and you`ll find out that all have the same od and width but the ones of the 907ie/851 have an id of 17mm the ones of the 900SS are 20mm. A '92 750SS has 17mm bearings, the '94 750SS has 20mm bearings. The reason could be a different axle diameter or bearing spacer design.
The bare rim is the same.
Posted: Mon Dec 23, 2013 10:47 am
by angelix
paso750 wrote:Angelix, it takes a bit of detective work to find out the difference but anyone can figure it out.
I thought so... I did check my "paperwork" and I though the difference could well be just in the spacers and bearing or in the manufacturers locations (sometime the same parts manufactured in different locationa for two different models have difference part numbers, I was told), but I was somehow hoping that someone here had the information at hand and could share it with me (all :mrgreen: )
I am also sure that the ST2 wheels could go up with little modification (if none) and these should be even lighter, but I would like to preserve the 907 ie original appeareance (although mine has a full 916 brake system and cast iron Discacciatis)
I always wanted to get a nice WHITE set of wheels that I can fit without having to take apart my bike and wait for the powder coating to do my wheels (the previous owner painted them grey) ; I only use the bike when I am visiting my parents in Italy, therefore I am always short of time and cannot afford having the bike in pieces waiting for some work to be done.
While I am doing the job I will also omologate the 180 at the rear as there is much more choice of rubber (the legal omologation is a must in Italy)
Anyway, thanks G. for your help, I really apreciated it.
900streetfighter wrote:I have spare 907 front wheel for sale. I'm in Essex. £75 + pp.
I will be sending you a PM...
Posted: Mon Dec 23, 2013 3:18 pm
by Derek
angelix wrote:I am also sure that the ST2 wheels could go up with little modification (if none) and these should be even lighter
The ST's have a 25mm spindle diameter so you'd need to play round with the bearings but I think the wheel itself should be ok.
Posted: Wed Dec 25, 2013 10:28 pm
by persempre907
Angelix,
the 180 rear tyre is already homologated.
On my papers is clearly written.If you have got an Italian 907 with Italian papers, try to check out. Let us know. Ciao
Posted: Fri Dec 27, 2013 11:05 am
by angelix
persempre907 wrote:Angelix,
My papers only show the 170 , unfortunately.
I did request the "nulla Osta" (authorization) from Ducati and they sent it to me straight away, but to get it on the bike papers i need to complete the process through the Mototorizzazione (Italian DVLA)
I have time though, I just fitted a set of new tires, so it will be next time when I need to replace the rear.
Posted: Sun Dec 29, 2013 1:05 pm
by persempre907
angelix wrote:My papers only show the 170 , unfortunately.
Ducati's mystery.
Perhaps, you have a very early 907, who knows...
Posted: Mon Dec 30, 2013 9:07 am
by angelix
Ducati's mystery.
Mine is # 315 , in fact came out with 300mm brakes and the 170 at the rear.
Ducati mystery? listen this one: some time ago I requested Ducati a declaration indicating the PRODUCION YEAR so I could use it to get the Road Tax EXEMPTION for over 20s.... they replied that my bike # 2000315 was manufactured in 1989 !!!!!!!!!!
