Oil leak
Posted: Sun Dec 22, 2013 6:23 pm
by plasmid
Anyone know what that small screw is for?
Looks like there's oil leaking from there.
The prev. owner had some rubbery epoxy over it which came loose.
Re: Oil leak
Posted: Sun Dec 22, 2013 11:15 pm
by Brutus
I've got the same issue.. Also like to know what they do.
Re: Oil leak
Posted: Sun Dec 22, 2013 11:21 pm
by plasmid
Brutus wrote:I've got the same issue.. Also like to know what they do.
Is it coming out enough to dribble towards the exhaust header?
Re: Oil leak
Posted: Sun Dec 22, 2013 11:23 pm
by Brutus
Yes, it dribbles.
Re: Oil leak
Posted: Sun Dec 22, 2013 11:26 pm
by plasmid
Brutus wrote:Yes, it dribbles.
Alright. Same here.
Re: Oil leak
Posted: Sun Dec 22, 2013 11:32 pm
by Brutus
Alright. Same here.
Got a picture of it in the past:
Re: Oil leak
Posted: Mon Dec 23, 2013 3:54 am
by ducinthebay
I always assumed it was the oil line feeding the head and cams. I assumed it was a cross drilled hole, and that was simply a plug. I have a spare head on the bench. I'll dare to take the screw out and see what's inside. There is some Loctite that seals and holds, but I don't know the part number off the top of my head.
Re: Oil leak
Posted: Mon Dec 23, 2013 9:52 am
by streetsurfer
Yes, a sealed oil gallery. I was advised not to try and remove them. Too soft. Sealed mine with rtv after a very thorough cleaning and it hasn't leaked.
Re: Oil leak
Posted: Mon Dec 23, 2013 10:09 am
by Derek
As stated above it's a blanking plug for an oilway drilling. They are on all the 2V engines and nearly all of them leak sooner or later. Use a thread sealant to keep the oil in.
Re: Oil leak
Posted: Mon Dec 23, 2013 11:45 am
by plasmid
ducinthebay wrote:I always assumed it was the oil line feeding the head and cams. I assumed it was a cross drilled hole, and that was simply a plug. I have a spare head on the bench. I'll dare to take the screw out and see what's inside. There is some Loctite that seals and holds, but I don't know the part number off the top of my head.
as streetsurfer mentioned, locktite rtv I guess.
Thanks for the suggestions.
