Fuel Pump Removal
Posted: Sun Jan 26, 2014 11:30 pm
by Jetdoc
Any advice on what to do or what not to do to get the fuel pump & filter out of the tank without screwing things up? Appreciate any advice.
Jetdoc
Re: Fuel Pump Removal
Posted: Sun Jan 26, 2014 11:44 pm
by Bock900r
- Remove the Tank Cap and Ring
- First Disconnect the Fuel Hose between the Filter and the Tank.
- Now the Hand in the Tank and push two flat clips togteher
Inside the Tank you can see the position of the clips in the round for the pump
Exchange all Fuel Hoses, it is easy now
Posted: Mon Jan 27, 2014 2:29 am
by Jetdoc
Thanks for the pictures, makes sense now.
Jetdoc
Posted: Tue Jan 28, 2014 1:07 pm
by Duc750
If like mine its stuck fast then you may need to unbolt the securing ring from the pump (loosen is probably enough) to allow some flex/movement and then woggle it all around again to get it to move
Posted: Thu Jan 30, 2014 6:52 pm
by du907
When you put the pump back in, don't forget to hook back up and check the rubber overflow hose that goes to the gas cap ring. If you forget this, then when you fill'er up, gas will pour out your overflow hose on the ground until the tank empties to about 3/4. Yes, that's experience talking.
du907
Posted: Thu Jan 30, 2014 11:31 pm
by higgy
+1 on gas everywhere
