Rubber cap hor. cylinder - 906/907
duske
Post by duske »
Hi.
Can anyone help med with the rubber cover for the belts. It is the one for the horizontal cylinder.
Ducati partnumber : 23510061A
http://www.stein-dinse.biz/Komplettange ... :8598.html
Re: Rubber cap hor. cylinder - 906/907
I had to rebuild mine as it was cracked around where the screws go in . I would have a look at the later model 2 valve motors , I aint sure ( G probly knows :) ) but I would think that the later SS motors would have the same piece on them and it may be available under a different part #
http://www.oiltalavante.com/DUCATI-23510061A/en . I just had a quick look and this lot have one for 15 euro , I have no idea where they are
H
duske
Post by duske »
Hi.
I have a order pending at them, but they are not able to get it. Have also tried Stein Dinze but no luck.
I will try to look at the other models to see if they could fit - thanks.
Derek
Post by Derek »
it's the same part on all the 904/944 engines - SS, Monster, ST2
actually it`s not http://www.stein-dinse.biz/Komplettange ... tyPhoto/0/ but if that tongue is cut off it probably will be.
duske
Post by duske »
I have ordered this and will try a small modification. I will report back if it works...
Derek
Post by Derek »
paso750 wrote:actually it`s not http://www.stein-dinse.biz/Komplettange ... tyPhoto/0/ but if that tongue is cut off it probably will be.
On further investigation I have to concede that your right :)
The Monster and SS models use that cap, part no 235.1008.1A
The 906, 907 and ST2 use the cap without the tongue, it's part no. is 235.1006.1A
The ST2 part should be readily available.
