Mikuni's
Posted: Sun Oct 02, 2005 9:01 pm
by BikerBard
Does anybody know where I can find part numbers for the 38 Mikuni's? I'm needing the numbers to the float bowls.
Donna
Posted: Mon Oct 03, 2005 3:42 am
by Skins
:cool:
Click on 'Downloads' in the Registered User Menu on the left of the screen - on Page 2 of the 'Technical Documents' section, there's a download of Haynes information about Mikunis. You may find what you want there. I didn't look, (I have DelOrtos) but you never know ...
Posted: Mon Oct 03, 2005 9:23 am
by paso750
there`s no such info in those manuals. You`ll have to give your dealer a call or search the web if you find a parts catalogue of a SS, Monster or Cagiva Elefant.
Gerhard
Posted: Mon Oct 03, 2005 9:33 am
by paso750
Donna,
go here:
http://www.ducati.com/bikes/catalogs.jhtml
then click on Model Year 2000 and download the parts catalogue of the M750.There you`ll find it on page 42/43.
Gerhard
Posted: Mon Oct 03, 2005 4:11 pm
by Skins
:thumbup:
Excellent help, Gerhard. You da man ...
Posted: Wed Oct 12, 2005 11:15 am
by 750pheonix
Am i right in thinking that any yamaha carbs from either TRX or TDM are suitable for the Mikuni modification?
Posted: Wed Oct 12, 2005 12:39 pm
by lceriani
Surely TDM 850 1991-95 and 1996-2001 series, but pay attention to jetting.
I use Mikuni BDST38 and found that Yamaha main jet (142.5) fits correctly, but size are quite different (factory M750 is 132.5 and M900 is 140). Also the needle is a different model.
LC
Posted: Wed Oct 12, 2005 10:31 pm
by 750pheonix
ok, i think i would spend more on jets and needles gettings than a new carb if i got a out of spec from Ebay.
Posted: Wed Oct 12, 2005 11:59 pm
by BikerBard
After a lot of searching I've found out that a '97 M750, an '89 Yamaha 1000 FZR, and a lot of the mid to late '80s GSXR's run this carb. I don't know about the jet sizes tho.
ronayers.com has the microfiche for the carbs, but a lot of the parts are NLA. Powersportspro.com has most of the parts still avaliable from Yamaha tho.
DG
Posted: Fri Oct 14, 2005 10:27 am
by lceriani
It was very difficut for me to find adeguate jetting for these carbs, because Mikuni sell them only as OEM and there are not aftermarket spare parts by Mikuni.
I found that original M900 main jets (size 140) are too small (probably to reduce emissions) and with my open air-filters the carburation was too lean. It was hard, but finally I found a pair of 148 and a pair of 165 (too big).
There's the DynoJet jet kit, but it is more expensive and have different jetting numbers.
LC
