paso panel compatibility question
Posted: Mon Oct 17, 2005 10:38 pm
by 750pheonix
Are the air-vent covers the same on 750 and 906 models?
I have to sort out a 750 fairing but it already have a 906 fairing (I bought it that way)... and also are the side panels the same shape and fixture points?
it would be useful to know to save time and money putting the 750 back to how it is meant to be.
thanks in advance
Posted: Mon Oct 17, 2005 11:50 pm
by Skins
:cool:
If it's any help (you may be able to compare 906 part numbers through a dealer, or some one else with a parts book) these are the part numbers for the Paso 740 panels:
air conveyors (air vent covers) right 037099730, left 037099720
side panels (below the seat) right 037099890, left 037099880
half fairings (hanging off the tank) right 037099770, left 037099773
Good luck!
Posted: Tue Oct 18, 2005 4:29 am
by ducster
:thumbdown:
Fairings of 750 / 906 aren't the same. 750 upper fairing (windshield) has mountings quite more to the side panels. 906/907ie mountings are placed more at "Top Position".
So the Side panels of 750 are quite a bit shorter.
Under-Seat fairings may be the same for all Paso series.
Fitting a whole 750 Fairing to a 906 or vice versa may work. Just measure the space between mounting holes at the fueltank.
You can get 906/907ie-fairings at http://www.airtech-streamlining.com/euroz/prodduc.htm , completely or in parts.
Greets,
ducster
Posted: Tue Oct 18, 2005 3:30 pm
by 750pheonix
ducster wrote:Fairings of 750 / 906 aren't the same. 750 upper fairing (windshield) has mountings quite more to the side panels. 906/907ie mountings are placed more at "Top Position".
The main reason i want to makie sure i have the 750 fairing is because it is much cleaner at the front... no nasty rivets holding the screen in place. much more what the bikes about... main feature of the bike actually.
ducster wrote:Under-Seat fairings may be the same for all Paso series.
This is good news... I bought 2 yellow pieces to replace a fairing that i am going to sell... whole 906 panels apart from tailpiece.
ducster wrote:Fitting a whole 750 Fairing to a 906 or vice versa may work. Just measure the space between mounting holes at the fueltank.
I doubt this would work... I have got a feeling there are some screws that need to be in place to hold the fairing on and in place. otherwise it's slips around.
ducster wrote:You can get 906/907ie-fairings at http://www.airtech-streamlining.com/euroz/prodduc.htm , completely or in parts.
P&P would double the price of the pieces... no i think i will hunt through the breeakers for repeairables.
