Coolant Expansion Tank Repair Bypass Modification
wineliving
- year: 1993
Coolant expansion tank repair/mod using 2006 Polaris Sportsman 450 coolant filler neck. Got tired of fixing the crappy plastic bottle and looking for a replacement. Wanted to keep it stock so if by some miracle someone makes one out of aluminum. Picture attached for reference.
- IMG_1480.JPG (129.41 KiB) Viewed 4328 times
Re: Coolant Expansion Tank Repair Bypass Modification
So if I got it right, you completely removed the coolant tank and only kept the coolant filler neck?
