oil pressure light?
Posted: Mon Oct 17, 2005 11:53 pm
by Rlbol
So I have gotten to spend some time with my 907 and noticed the oil pressure light dimmily lite every so often. Any suggestions or places to start looking? And yes there is oil!
Posted: Tue Oct 18, 2005 9:14 pm
by etheriault
Rlbol,
How long did you have this problem? If you have it for a long time, I would suspect that the pressure is OK. I would first check all the connections from the sensor switch to the dashboard. The sensor is located to the front of the engine, below the oil filter. The sensor is providing a return path to ground when it doesn’t sense pressure to turn on the light on the dashboard. If the problem still occurs after all the connection have been cleaned, I would change the sensor.
