Grose Jets
Posted: Thu Feb 26, 2015 8:14 am
by Giscard
Are the Grose jets no longer available for the Weber 44 DCNF. I have tried following up on contacts from this site but have failed miserably. I am based in the UK but accept that they will probably only be obtainable in the U.S. if at all.
Re: Grose Jets
Posted: Thu Feb 26, 2015 9:17 am
what size are they ?
I replaced all parts in my Weber a few years back and had no problem finding them all.
http://www.dellorto.co.uk/merchandise/p ... tionID=135
Re: Grose Jets
Posted: Thu Feb 26, 2015 11:47 am
by higgy
From what I understand Mr Grose turned the biz over to his son a few years back and no one has heard from either of them since. You may still find one at antique carb shops in the UK and Canada
I believe they originally came from Stromburg back in the late 40's early 50's and had been "rediscovered by Mr Grose "in 1970
you may try D & G Valve Mfg. Co., Inc. on 8 Mt. Vernon Street,Stoneham, MA 02180
Phone (781) 438-1789
Re: Grose Jets
Posted: Thu Feb 26, 2015 5:17 pm
by Giscard
Thanks for the feedback.
Paso 750 the link you gave refers only to needle valves, which I have a couple of. I thought I would see of the Grose jet was any improvement over that.
Higgy I had already found the D & G Vale Mfg Co but apart from Arlen Grose being named I could not locate an email address or a website. I have my doubts that it will be of much use to me as it appears a small operation. I will just have to stick with the needle valve.
Re: Grose Jets
Posted: Thu Feb 26, 2015 8:37 pm
by ved
you can try here.
last time, when i talked with him, he told me that he can get weber parts
English is no problem
http://www.shopssl.de/epages/es534287.s ... ontactForm
Re: Grose Jets
Posted: Tue Mar 03, 2015 2:37 pm
by Giscard
Hi ved. I emailed him but to date I have had no reply, which I take as product unavailable. Guess I will stick with the needle jet after all. Presumably the Grose jet was not universally accepted.
Re: Grose Jets
Posted: Thu Mar 05, 2015 8:10 pm
by smartino67
Giscard wrote:Are the Grose jets no longer available for the Weber 44 DCNF. I have tried following up on contacts from this site but have failed miserably. I am based in the UK but accept that they will probably only be obtainable in the U.S. if at all.
I bought mine from moss-europe.co.uk (valve code GAC9201X) one month ago; I think they are still available at few pounds. I had many troubles with Weber due to the original needle valve. By reading this very useful forum I discovered these jets and their (on paper) benefits. Now, after replacing, I can confirm they work because they were able to solve most of carburation problems
The purchased Grose jet doesn't fit perfectly because of :
1) different thread pitch (a little bit different, solved by using more layers of teflon to win the gap)
2) the height of jet body, greater than original valve (solved by adjusting float height)
This improvement, even if needs a few easy adjustings, wins 70-80% of Weber problems.
So, my suggestion is to try with them, in case you don't succeed in finding them elsewhere
