Leaking Neutral switch
Posted: Mon May 11, 2015 7:24 pm
by ridgeskimmer
My Neutral switch at the back of the engine is weeping oil. I have tried tightening but still leaking. Just wondering if fitting a new one will fix this and if anyone has any links to wear I might get a new one?
Many thanks
Re: Leaking Neutral switch
Posted: Tue May 12, 2015 8:46 am
by Derek
Available from Steine Dinse -
http://www.stein-dinse.biz/Complete-par ... 48919.html
It is the same as fitted to the SS and Monster models up to 1997, so should still be available from any Ducati dealer.
Posted: Tue May 12, 2015 9:14 am
by paso750
where exactly does it leak? The neutral switch is installed with a washer/shim.
In case you plan to replace that note it exists in at least two different thicknesses. You`ll need the right one to make sure your switch works correctly.
Posted: Tue May 12, 2015 9:43 am
by ridgeskimmer
paso750 wrote:where exactly does it leak? The neutral switch is installed with a washer/shim.
It looks as though its just coming out from where it screws in. Just a trickle it's not too bad. Ive not had it right out to see if there is a washer/shim fitted. Thanks
