Starter problem
Posted: Wed May 27, 2015 3:30 am
by sean215
hello. my bike just started to have a problem with the starter. i start up the bike and the stater it spins but doesn't turn the engine. second try it spin and turn engine little and spin again. and the starter was new. i replace it last year from Rick's Motorsports Starter Motor. is anyone know have a problem like this and know how to fix it???
thanks
Re: Starter problem
Posted: Wed May 27, 2015 4:32 am
by ducinthebay
Sounds like a starter sprag. Otherwise known as a clutch. Its a one way clutch that connects the starter power to the crank. There is a fine spring like one on a seal all around it. If it gets stretched, it will be come intermittent. Just did it on an ST2.
Re: Starter problem
Posted: Wed May 27, 2015 7:37 am
by oceanhunter
If you can get the sprag bearing out and inspect the inner and outer surfaces of the bearing hubs
for any roughness/uneven surface if this has occurred then get it skimmed slightly(outer)
and use some emery cloth to dress the inner and fit a SKF
seal spring that best suits the bearing proper,don't worry to much if the rollers have slight damage
to them as I had one on mine and it has not caused any problems!Done 50,000 k's no worries.
Re: Starter problem
Posted: Thu May 28, 2015 2:24 am
by sean215
thank for replying guys. is there a way to repair the starter sprag? i found one on ebay for 150 \
http://www.ebay.com/itm/331544858448?it ... 23&vxp=mtr
Re: Starter problem
Posted: Thu May 28, 2015 10:33 pm
by nickta
Hi Sean.
The spring is usually the culprit with the sprag, and can be replaced with one off an SKF Oil Seal. There is a few posts here that cover it all. A KTM Sprag (new) is also available that is a direct replacement, and is about half the price of a genuine Ducati (don't figure?) unit. Again, the posts here have all that info.
Have a look at posts:
http://forums.ducatipaso.org/viewtopic. ... ilit=sprag
and
That should keep you busy!
Cheers.
Nick.
Re: Starter problem
Posted: Thu May 28, 2015 11:09 pm
by ducinthebay
Or just google Ducati starter sprag clutch. All basically the same in function. (KTM too)
Re: Starter problem
Posted: Tue Jul 14, 2015 4:21 am
by sean215
hello guys. lately i been busy. just have time to open up and see what wrong with the starter sprag. i found out that rollers have some damage. few of the rollers is bent at the gap where the spring fit in and the new spring wont fit in so i have to use sand paper to sand most of the damage part down. so the spring can fit in the gap. since i got a new spring. the inner surface have some uneven surface. should i just use sand paper to smooth them out? please let me know thanks guys
