Steering head bearings
Posted: Wed May 27, 2015 5:32 pm
by fasterdammit
I haven't dug into it yet, but I can tell I'm due for new steering head bearings. Just testing the waters before I start pulling things apart ... any gotchas I should keep in mind?
Re: Steering head bearings
Posted: Wed May 27, 2015 6:15 pm
The only tricky part is removing the inner race of the bottom steering bearing from the steering stem.
Posted: Wed May 27, 2015 6:19 pm
Posted: Thu May 28, 2015 6:48 pm
by ducinthebay
Certainly get tapered roller bearings instead of ball bearings. Last longer, feel better. Of course, good grease is important too. Plenty of it. Pretty hard to over grease a low motion bearing like the headset. Set it up with just tad of preload.
Posted: Thu May 28, 2015 10:20 pm
by Mc tool
Unless you have some pretty trick bearing removing tools that lower inner bearing race is probly best ground ( dremel ) nearly right thru in 2 spots and then split with a cold chisel
Posted: Fri May 29, 2015 12:01 pm
by Brutus
Mc tool wrote:Unless you have some pretty trick bearing removing tools that lower inner bearing race is probly best ground ( dremel ) nearly right thru in 2 spots and then split with a cold chisel
Exactly the way I did it the last time. Without any damage on the stem and triple tee I'd managed to get it off. At a certain point it cracks and it will slide right off. Before I had used plenty of WD40 and let it sit for a day.
Posted: Mon Jun 08, 2015 9:43 am
by riascns
I normally cut an x pattern with a small angle grinder (a partly worn blade makes it easier as the diameter is smaller, but still be careful) and then knock out the triangular shaped bit with a cold chisel.
To get the lower bearing cup out of the headstock, I normally run a bead of weld around the cup surface after cleaning the grease off. When the weld cools it shrinks the cup and makes knocking it out very easy. A clean up with emery paper and a smear of copper grease makes getting it out the next time easier.
