Fuel tap
Posted: Tue Oct 13, 2015 9:16 pm
by prospero75
Can the fuel tap on the tank be removed? I think mine is clogged - I've put the new fuel pump in, but nothing pumps out...
Looking at the parts fiche, it appears to screw out - hopefully the tank has standard threads...
Re: Fuel tap
Posted: Tue Oct 13, 2015 9:23 pm
is it possible the power connections on the new pump are reversed?
Re: Fuel tap
Posted: Tue Oct 13, 2015 9:47 pm
by prospero75
It's pumping out of the fuel pump, past the fuel filter, just fine. Nothing comes out once I hook the fuel line up to the interior hard line.
Re: Fuel tap
Posted: Tue Oct 13, 2015 10:10 pm
and those connections are correct, too? Just asking because the bit where hose "b" connects to is a one way valve
Re: Fuel tap
Posted: Tue Oct 13, 2015 10:38 pm
by prospero75
ah, yes - thank you, I've confused the one way valve with the fuel tap. So I need to figure it out tomorrow, when there is light.
The fuel pump fires up and pumps up to pressure, but goes nowhere - maybe the steel line is plugged.
Thanks, much!
dj
