tank breather
Posted: Sun Oct 18, 2015 8:36 pm
by jjw
Had the tank off and it was laid down leaning forward. Found fuel leaking out through the central round support.
Is there a breather there in the central front support or is my tank leaking?
Cheers J
Re: tank breather
Posted: Mon Oct 19, 2015 7:36 am
by Revhead
Hi J,
Not a tank breather, I'm afraid... A known issue on the earlier tanks, where they start to leak around the front centre support (the small tack welds that fix the round support to the tank)...
Whereabouts in the Netherlands are you?
Bas
Re: tank breather
Posted: Tue Nov 03, 2015 9:11 pm
by jjw
Hi Bas,
I am in Middelburg, you?
The leak is small, doesnt leak while driving I think. I see evidence of a fix with some kit. I will have to look at it again to see what I can do with devcon or something. Any suggestions?
Cheers J
Re: tank breather
Posted: Tue Nov 03, 2015 9:17 pm
by Sheff928
Re: tank breather
Posted: Tue Nov 03, 2015 9:23 pm
by jjw
Yes, thats indeed an option I had not thought about, I was thinking of a fix from the outside.
I have heard mixed report about these sealers. Is there experience on the forom with this kind of fix?
Cheers J
Re: tank breather
Posted: Tue Nov 03, 2015 9:42 pm
by Sheff928
I am faced with a leak from the seam of my 750SS, and after quite a bit of reading, I felt sufficiently reassured to part with my own money (!) to purchase similar items from ebay, but bought the quart size in order to treat a few tanks at once. I haven't done it yet but many reports on this fix are very positive.
I might use JB Weld first just to make sure...
Re: tank breather
Posted: Tue Nov 03, 2015 10:48 pm
by higgy
forget JB weld
Re: tank breather
Posted: Tue Nov 03, 2015 11:08 pm
by Sheff928
Solvent resistant - including petrol/gasoline - and strong as hell; I'll be using JB Weld.
