stock rear shock
Posted: Mon Nov 07, 2005 2:37 am
by bavarian
Is the stock rear shock on a '88 750 Paso rebuildable? Mine is starting to seep oil.
Posted: Tue Nov 08, 2005 8:08 pm
by Finnpaso
If U have Öhlins, ITS that, but i dont know that older Marzhocci in 750. Btw, that Öhlins is much better shock :thumbup:
That 907 later model rear Marzhocci is, cause mine was rebuild by Öhlins maintainer. Also i find rebuild kit from Ducati, but i am not sure, is it anymore available.
Finnpaso
Paso 750
Paso 907IE
rear shock
Posted: Fri Nov 11, 2005 10:09 pm
by bavarian
My Paso has the stock Marzocchi shock. I'd like to get a used Ohlins for it. What part/model number Ohlins will fit a 750 Paso? I'm also going to call the dealer Monday and find out if there is a rebuild kit for the Marzocchi.
Re: stock rear shock
Posted: Sun Nov 13, 2005 10:16 am
by ved
bavarian wrote:Is the stock rear shock on a '88 750 Paso rebuildable? Mine is starting to seep oil.
at the moment in ihbäh
http://cgi.ebay.de/Ducati-PASO-906-Marz ... dZViewItem
or
http://cgi.ebay.de/Ducati-PASO-907-i-E- ... dZViewItem
rear shock
Posted: Sun Nov 13, 2005 10:29 am
by bavarian
Thanks for the link ved, but that shock and rebuild kit won't work on a 750's shock. The rebuild kit won't fit the shock and the shock is too large for the limited space on the 750 Paso from what I have read.
Posted: Sun Nov 20, 2005 3:00 am
by davidhughrose
I have the same seeping issue with my 88 Paso shock. Works Performance produces a shock for the Paso. The remote reservoir installs with hose clamps, so it's not the cleanest install. My shock continues to work pretty well despite a drip here/there, so I haven't installed the WP unit yet. I plan to weld up an aluminum clamp of some sort, that will make the shock worthy of being installed on my Paso. Hose clamps!
rear shock
Posted: Sun Nov 20, 2005 8:19 pm
by bavarian
The Works Performance shock is only $350 as well. If you do get one let me know how it feels. I've also had a few crazy thoughts of just getting an Ohlins, but have been so far unable to find any info as to which model would fit the Paso.
Posted: Wed Nov 23, 2005 6:23 pm
by Finnpaso
Hi !
Original Paso 750 Öhlins is modell: CA 508, but i am 98% sure, that You cant find such new from any Öhlins shop anymore.
Finnpaso
Paso 750 -89
Paso 907IE -91
ST4S -02 (tomorrow i got it from Germany) :lick: (cant wait!!!!)
