Doing the 900ss CV carb swap
Posted: Wed May 11, 2016 11:25 am
by viper1
I decided to pick up a set of 94 900ss carbs to toss on the 750. I'm sick of dealing with the Weber issues! Whats all needed to make the switch? The carb manifolds & rubber gaskets. I'll end up getting separate filters....anything else I need to get or should know?
Re: Doing the 900ss CV carb swap
Posted: Wed May 11, 2016 2:13 pm
by paso750
check the Technical FAQs
Posted: Thu May 12, 2016 1:25 am
by viper1
paso750 wrote:check the Technical FAQs
Where do I find this?
Posted: Thu May 12, 2016 6:58 am
by paso750
Posted: Thu May 12, 2016 11:09 am
by viper1
paso750 wrote:
Da
Thank you!!
Posted: Thu Sep 20, 2018 1:47 pm
by Rickman
I just did mine, and I am using a small vacuum fuel pump, (3psi), with a return line that t's off just before the carbs. All the info was on the forum.
Posted: Mon Sep 24, 2018 2:44 pm
by Rickman
I'm setting mine up this week, once the carbs are on, you'll need a small vacuum fuel pump, i replaced the screw in my intake manifold with an M5 x 6mm brass fitting, my fuel line comes out of the tank and goes to a fuel filter, then the vacuum fuel pump then to a t or y, one line will go to the carb and the other is a return back to the tank. They also recommend a small bottle for the two vent tubes and the float bowl overflow line also. Once mine is set up, I'll add some pics if you'd like.
-Rickman
