Leaking Clutch Fluid ???
Posted: Sun Nov 13, 2005 5:54 pm
Can someone help please?
My Paso has lost all pressure on the clutch lever. I can press the lever and it will not push those clutch plates. It just feels really lose. There's no problem with the master cylinder as I had it overhauled and tested and it seems to pump fine. Have checked the hydraulic cable and that does'nt seem to have any leaks. Finally, have blead the air release nut to allow any air out.
I can only think that there's a problem with the slave slave cylinder (i.e the one attatched to the clutch cover).
It did seem to make a horrible creaking and screeching noise each time I pressed the clutch, but me being silly kept on riding for at least another 2000 miles (as it allways made a small noise).
I am hoping that I might have to change the rubber seal on the slave cylinder rather then the whole cylinder. Has anyone else had this problem, if so, where can I get my hands on this simple part?
Cheers guyz and girls?
