Petcock
Posted: Tue Nov 22, 2005 1:20 am
by BikerBard
I found a place online that has petcocks for the 906. Will they also fit a 750? Mine is leaking and doesn't look like it's rebuildable.
Donna
Posted: Tue Nov 22, 2005 8:47 am
the tank is the same so the petcock will fit. Where`s the link ?
Gerhard
Posted: Wed Nov 23, 2005 1:05 am
by BikerBard
http://www.powersportspro.com/partsfish ... yfiche.asp
Not sure if it's nla or not, but it gives the part #. If my dealer wants too much for it, I may give these guys a call and find out.
They do have alot of other stuff for Pasos.
DG
Posted: Tue Dec 06, 2005 11:51 pm
by BikerBard
After an exhausting search, I am still unable to find a petcock. Do any of y'all know where I can get one? Or an alternative that will work?
DG
Posted: Wed Dec 07, 2005 1:00 am
by DesmoDog
What's the part number?
Posted: Wed Dec 07, 2005 1:13 am
by BikerBard
58840011A
Posted: Wed Dec 07, 2005 5:11 am
by DesmoDog
Hmm... probably no surprise but I struck out on that part number.
I'd suggest checking out bevelheaven.com, he's got a few different types and one of them may work. There are pictures and descriptions to help you decide. Otherwise, if the one you have is riveted together, you may be able to drill out the rivets and rebuild it. Then you need to drill and tap the body of the petcock so you can reattach the plate to it. The rubber piece inside of it is likely avalable though, I seem to remember reading about someone doing this. Worst that can happen is you ruin it, but it leaks anyway, so...
My guess is one of the earlier parts will work, and will have the advantage of being rebuildable. About all you need to worry about is the thread size and the orientation of the outlet.
Posted: Wed Dec 07, 2005 5:28 am
by Skins
Have you checked out the Parts Interchangeablity List in 'Links' under the Registered User Menu on the left?
Posted: Thu Dec 08, 2005 2:13 am
by BikerBard
Bevel Heaven has them for about $25.
Posted: Thu Dec 08, 2005 2:51 am
by Skins
Hey! Good stuff!
I reckon the problem part is going to be the instrument case cover ... there won't be enough complete instrument sets available to fill the need for clear case covers ...
