Rear brake pump
Posted: Sat May 05, 2018 2:26 pm
by Mirinn
Hi, can you tell me which rear brake pump would fit the 906 Paso?
I wanted to rebuild only the piston, but I have not got anywhere in the EU, I will probably have to replace the whole brake pump
Re: Rear brake pump
Posted: Sun May 06, 2018 8:31 am
by Derek
Brembo seals and repair kits can be bought from KTM dealerships. Make sure that the model has the same master cylinder.
https://www.motorcyclespareparts.eu/en/ ... ol-duke-94
Re: Rear brake pump
Posted: Wed May 09, 2018 2:08 pm
by Mirinn
my piston is 11mm and they do not have a supply
Re: Rear brake pump
Posted: Fri May 11, 2018 10:59 am
Re: Rear brake pump
Posted: Tue May 15, 2018 1:48 pm
by Mirinn
it will be it, thank you
Re: Rear brake pump
Posted: Wed May 30, 2018 10:53 am
by Derek
For information. Repair kits for the Brembo PS11 rear master cylinder (and many more) are available from Gutsibits in the UK.
https://www.gutsibits.co.uk/pr/TheShop/ ... e=4#topbar
Re: Rear brake pump
Posted: Tue Jun 05, 2018 12:52 pm
by Mirinn
I ordered here, thank you for the tip
https://www.stein-dinse.biz/Ducati/Brem ... 16254.html
I have a mounted brake and it works as it should
