Page 1 of 2
headlight ducati 750--900 sport.
Posted: Sat Oct 27, 2018 4:56 pm
by 900SS90
I need a headlight for my 900 European, I have the one of my English motorcycle, not valid to drive in Europe.
If you are in England and have the same problem, I can make a change.
If you have a European one, for sale, on your shelf, I can also buy it.
Re: headlight ducati 750--900 sport.
Posted: Thu Nov 01, 2018 4:21 am
by HIGHWAY89
Gday mate, if the English light is the same as Australian I could do a swap as I only have the European unit, if that would help, cheers
Posted: Thu Nov 01, 2018 7:49 am
by Frank.61
Just in case you do not succeed: a new one (CEV 287 288).
https://www.ebay.es/itm/FARO-ANTERIORE- ... 2855320827?
Good luck!
Posted: Thu Nov 01, 2018 7:58 am
by Frank.61
Please do check the CEV numbers on your headlight, to be sure it's the correct one.
Posted: Thu Nov 01, 2018 8:32 am
Frank, that headlight for the later 900SS does not fit the 89/90 900SS which used the same one as the 750Sport and F1.
Posted: Thu Nov 01, 2018 9:03 am
by HIGHWAY89
Anyone know the correct CEV numbers for the aussie headlight, cheers
Posted: Thu Nov 01, 2018 9:48 am
Just have a look at the parts catalog
067038200 is for rhs traffic
067038210 for lhs
Posted: Thu Nov 01, 2018 9:59 am
by Frank.61
If someone has a clear picture of the headlight with brand (CEV, Carrello etc.) and numbers or even the dimensions I can try to find out whether it was also used for other vehicles (Fiat?).
Production numbers were so low in the mid eighties, chanses are it was not a "Cagiva special".
If I could get the dimensions also it would be helpfull.
Just let me know if you want me to look for a source .....
I hardly know the 900ss but I've done this exercise a few times for my Bimota and some Cagivas a few years ago.
First items I search for/buy when I have a restoration project are all items related to lights and rubber parts.
Posted: Thu Nov 01, 2018 10:46 am
by 900SS90
Then I will go to my garage, I will try to photograph the two lighthouses.
I've tried it before, but the numbers are not clearly seen by the reflection of the crystal.
I'll try again.
Posted: Thu Nov 01, 2018 6:23 pm
by 900SS90
Frank.61 wrote:If someone has a clear picture of the headlight with brand (CEV, Carrello etc.) and numbers or even the dimensions I can try to find out whether it was also used for other vehicles (Fiat?).
komme aus der Garage zurück
Dies sind die Anzahl der Scheinwerfer und die Maße.
Der Leuchtturm rechts und der Leuchtturm links.
Es wäre für alle gut, zu wissen, ob ein anderes Fahrzeug die gleichen Scheinwerfer hat.
Grüße
Posted: Thu Nov 01, 2018 6:25 pm
by 900SS90
Posted: Thu Nov 01, 2018 6:38 pm
by 900SS90
Posted: Thu Nov 01, 2018 11:05 pm
by Frank.61
So that I understand it correctly: do you need a CEV 304 or a CEV 364?
The CEV 304 I see new ones on ebay, no 364 though ....
Posted: Fri Nov 02, 2018 4:22 pm
by 900SS90
Frank.61 wrote:So that I understand it correctly: do you need a CEV 304 or a CEV 364?
Danke Frank
Posted: Thu Nov 15, 2018 9:59 am
by 900SS90
HIGHWAY89 wrote:Gday mate, if the English light is the same as Australian I could do a swap as I only have the European unit, if that would help, cheers
I still have the English lighthouse, for the left.
HIGHWAY 89, do you still need it?
You have a PM
