Side stand switch
Posted: Sun May 12, 2019 9:44 pm
by AmcG
Hi
How do I remove it? It’s a single wire type. (I have removed the sidestand already)
Re: Side stand switch
Posted: Mon May 13, 2019 8:14 am
by Derek
Unless it's different from the 907 switch, loosen the lock nut then it just unscrews.
Posted: Mon May 13, 2019 11:12 am
by AmcG
Thanks... I’ve asked the question badly, I want to discard the switch. Do I earth the wire?
I don’t want any form of cut out. The side stand is removed.
Alistair
Posted: Mon May 13, 2019 12:55 pm
by Derek
If you earth the wire the light in the dash will light up. If you don't want it lit leave the wire disconnected.
Posted: Mon May 13, 2019 4:45 pm
by AmcG
Thanks! Will get by without the light.
