Charging problem...no kidding....
unclezip
Post by unclezip »
Intermittant battery dies....charging 13.2 or so in the shop...half hour of riding almost kills the battery..no charge light..yellow wires fixed last year so, are we still using the shendengen regulator?...or are there better options....thank you so much..
92 907 i.e.
2016 F6B
2001 MG Jackal
1980 XS Eleven/1960 Watsonian sidecar
1974 Norton Commando/Factory Production Race
unclezip
Re: Charging problem...no kidding....
Post by unclezip »
I am going to put a digital voltmeter in....hate not knowing whats going on.....
92 907 i.e.
2016 F6B
2001 MG Jackal
Shindengen is good.
du907
Post by du907 »
Not exactly sure whats going on with your bike, but after you sort it out go to this site and buy the upgrade. The kit these guys supply is worth every penny.
I have had my engine balanced, blueprinted, heads ported, etc. and the compression is up and well it's a stout engine. Was hard to get it started and the battery was always low. Put this upgrade on the bike and it kicks off immediately, no dragging, no whining, hit the starter button and it's running. Great product that works.
https://motolectric.com/makes/ducati.html
Bryon
Oh, clean up your grounds, check the wires you where talking about and see if they are getting hot and deforming.
unclezip
Post by unclezip »
du907 wrote:Not exactly sure whats going on with your bike, but after you sort it out go to this site and buy the upgrade. The kit these guys supply is worth every penny.
Bryon
Looks like a nice upgrade...I will go with that....any advantage is good.....I did the alt wires last season and Im going to go through the grounds and such this weekend....and I think Ill upgrade the regulator also....insurance...thanks..
92 907 i.e.
2016 F6B
2001 MG Jackal
Is this a new issue or did you have it already before the regulator was replaced? Or in short, is the regulator wired correctly? ;)
unclezip
Post by unclezip »
paso750 wrote:Is this a new issue or did you have it already before the regulator was replaced? Or in short, is the regulator wired correctly? ;)
No problem before....I did the wiring upgrade last weekend, and installed a digital guage on the dash. Charging 13.6 @ 25k drops to 12.8 at idle...new battery, 12.8 volts engine off.....runs good...
I guess I'd like to see 13+ at idle but I think I can live with this...
92 907 i.e.
2016 F6B
2001 MG Jackal
Derek
Post by Derek »
Even 13.6V is a bit low. You should really be seeing 14.0V + at over 2,000 rpm.
I have a Shindengen FA020H and get around 13.6V at idle and a steady 14.2V above 2,000 rpm.
unclezip
Post by unclezip »
Derek wrote:Even 13.6V is a bit low. You should really be seeing 14.0V + at over 2,000 rpm.
I agree...I think ill go with that....
92 907 i.e.
2016 F6B
2001 MG Jackal
unclezip
Post by unclezip »
Whats the difference between the fa020h and fh020aa.....is it just the charge light?
92 907 i.e.
2016 F6B
2001 MG Jackal
Derek
Post by Derek »
Sorry, I probably have you the wrong Shindengen number. I was writing from memory, I'm in Turkey right now. It is a MOSFET regulator with no provision for a charge light.
http://roadstercycle.com/
Everything you need to know
unclezip
Post by unclezip »
So I went with the fh020aa and all is good in my Paso world, for now....14.5 at 2k....steady....
Tnx for everyones input......
92 907 i.e.
2016 F6B
2001 MG Jackal
Derek
Post by Derek »
Good to hear. Thanks for the feedback :thumbup:
unclezip
Post by unclezip »
I also put a small volt meter just under the coolant guage, I like it and I think I'll use it on my other old bikes. Nice to know whats going on....amazon $12.....
92 907 i.e.
2016 F6B
2001 MG Jackal
