Rear shock size
Posted: Thu Sep 05, 2019 11:45 am
by AmcG
Hi
Can anyone confirm the dimensions for the rear shock?
Length eye to eye- 365mm
Eye holes -10mm
Across flats -22mm
Many thanks
Alistair
Re: Rear shock size
Posted: Fri Sep 06, 2019 5:24 pm
the dimensions
Re: Rear shock size
Posted: Fri Sep 06, 2019 5:33 pm
by AmcG
Hi
Once again, super helpful.
Alistair
Re: Rear shock size
Posted: Sun Sep 08, 2019 4:42 pm
by Ronald
Hi Alistair,
Maybe this is also interesting for you: the 'technical data sheet' of the Öhlins DU508 shock absorber which was installed on the first 950 or so 750 Paso's. The form is named 'Mounting instruction', but there are no instructions on it whatsoever
Nevertheless, there are some sizes on it.
Re: Rear shock size
Posted: Sun Sep 08, 2019 4:56 pm
by AmcG
Ronald
Thank you! It confirms the length.
Alistair
Re: Rear shock size
Posted: Tue Sep 10, 2019 8:57 am
only in the very early P750 not in the 906 or 907IE
Re: Rear shock size
Posted: Sat Sep 14, 2019 10:42 pm
by AmcG
New shock...
