88 Paso throttle cable
Lionel
Post by Lionel »
After finding and receiving a Weber 44 DCNF-113 thanks to Dave73.
I've contacted the local Ducati dealer to get new cables choke and throttle and found they are no longer available. Even googled with no luck. Any one know of a suitable replacement
1988 Paso Limited
1929 Rudge special
2008 Ducati S4rs
97 TRX 850
smartino67
Re: 88 Paso throttle cable
Post by smartino67 »
Hi Lionel.
This is from Italy (I assume 906 and 750 fitting the same cable) :
https://www.officine08.it/p75088_cavo-g ... -paso.html
Hope helping you
murphus
Post by murphus »
I found mine at https://www.stein-dinse.biz/ . Throttle cable was item #400520157 and choke cable was item #037054130-Z. Both fit/work perfectly and were pretty inexpensive.
1973 BMW R75/5
1976 Suzuki GT185
1983 Lavarda RGS 1000
1988 Ducati Paso 750
1995 BMW K75
Andrew2
Post by Andrew2 »
smartino67 wrote: Fri Feb 25, 2022 7:06 am Hi Lionel.
Hope helping you
It says it's discontinued from this site.
randtcastell
Post by randtcastell »
I had my throttle cable made up by Motion Pro: https://www.motionpro.com/ I sent in my old ones and in 2 weeks got replacements. Good luck! :^)
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
murphus
Post by murphus »
I'll second Motion Pro. I've bought from them for other projects and always good quality and properly made. Only down side is you can't ride while you're waiting for cables, and if he doesn't have any old ones for patterns ...
1973 BMW R75/5
1976 Suzuki GT185
1995 BMW K75
