Loss of strokes
Posted: Sun Jan 15, 2006 9:40 am
by persempre907
Hi everybody,
my 907, when the motor is hot, sometime loss a stroke, at steady fast, and only about 3000 RPM.
Someone can tell me why :confused: ?
Ciao.
Posted: Sun Jan 15, 2006 2:11 pm
by DesmoDog
Is the battery in good shape? When you start the enigne, does it turn over easily or does the battery seem to struggle a little to get it to spin?
My 907 had the same problem, turned out the battery was on it's way out. New battery solved it.
Posted: Mon Jan 16, 2006 5:26 pm
by persempre907
The battery should be in great shape because I have changed it 1 month ago!
But therefore the battery seem to struggle a little to get it to spin!
Have I to charge it?
Ciao.
Posted: Mon Jan 16, 2006 5:40 pm
by DesmoDog
Most batteries should be charged before use... but I think a long ride should be enough to charge it? So... it couldn't hurt but I wouldn't count on it fixing it.
Posted: Tue Jan 17, 2006 2:15 am
by Skins
:cool:
The battery should show a charge reading of 12.5 volts. If the reading is over 12 volts and the starter still does not spin quickly, then you have other problems, perhaps in the wiring. In that case, you should check and clean all the contacts in the wiring.
Posted: Wed Jan 18, 2006 11:11 pm
by persempre907
It's so!
I will clean all the contacs.
But you think that it can make loss the strokes?
Posted: Wed Jan 18, 2006 11:36 pm
by Skins
:cool:
I think it is possible, but cleaning the contacts may help the starting, in any case.
Posted: Thu Jan 19, 2006 7:03 pm
by Paul
Francesco,
If the battery contacts are really dirty / corroded they can reduce the available power to the point where it can just bring the solonoid in and barely turn the motor over. Make sure the contacts are clean and the terminals are tight.
Good luck.
Paul
Posted: Sat Jan 21, 2006 7:04 am
by persempre907
Really, only after 1 month that I've changed the battery his contacs seems corroded. It seems strange to me.
Thanx.
