Certificate of conformation COC
volucianus
I am searching a COC for my Ducati 906 Paso.Can somebody help me with a copy or original?
Re: Certificate of conformation COC
Have you tried to contact your countries main Ducati importer?
Maybe this is what you're looking for https://shop.motodepocaservizi.it/prodo ... aso-906-2/
Not sure of your reasons for needing the COC but I went through (the normally successful) channels to get the COC (for my 1990 906 paso) so I could demonstrate the NOx levels were below the London limit to avoid a pollution charge when taking her out. After much communication Ducati Italy declared they did not have this data. I know for slightly younger ducatis (early 90’s) people HAVE got a declaration of acceptable NOx levels. I would guess NOx testing for homologation was just not bothered with in the 80’s but became an option in the 90’s so they recorded it because the could? Hope this makes some sort of sense! As an aside there are a couple of test centres inLondon that will test and record the NOx values so your bike becomes excerpt. (Costs £175 though!!!!!!!!)
