cam pulley
Posted: Fri Mar 17, 2023 7:23 pm
hi
the 906 developed a rattle the other day, got me home and when checked over found the pulley on the vertical cylinder was loose so stripped the head off and found quite a bit of wear on pulley bore however fortunately no measurable wear on bore got a chance of a couple of pulley from a 916, as far as iI can tell the are the same except the 916 ones have no flange, is this correct?
cant physically measure them to check as they are at a mates who has no measuring gear and lives too far away just to pop around
thanks
Paul
thanks
Paul
