750 vs 906 vs 907 dash
Posted: Tue Apr 04, 2023 11:26 pm
Hi.
Over the last few years I have come into the possession of a 906 and a P750 to share the shed with the 907. I have finally got around I starting them up and getting them all serviced and all the other good things to make them work.
The 750 is now in numerous pieces, but is a runner. The one thing that is driving me nuts is the oil temp gauge doesn’t register. The sensor tests out ok (about 2kohm at ambient temp) and I have a spare just in case. The wiring buzzes out all the way through which leaves the gauge itself. So the $90 question. Is a gauge from the water cooled version the same as the oil cooled version? Ignoring the black plate that screws to the front. I have a dash from the 906 that is past use by, but I have a replacement, so it would be a matter of removing the temp gauge, change the plate and screw it in. Without a working oil gauge I can’t test the coil resistance of the oil gauge to compare. I do have a water temp sensor which I haven’t tested yet, so that is next. Any thoughts?
Nick
Nick
