906 fairings to 907IE?
Has anybody done that??? and if have, then: Is there any problem with that modification? I know very well, that front upper fairings are different in 906 and 907IE, but seems, that 906 front upper fairing have same connection system, as in 907IE. All info will be helpful. Thanks :thumbup:
Re: 906 fairings to 907IE?
Hey Guy
I am planning to have a definitive answer for you over the next couple of days.
Started stripping my 907 bodyworks recently but the weather has me stalled. Have a ride in coming up next Saturday so i will try to fit my 906 covers. At first glance the tank mounts appear to have different spacing but should have details in the next couple of days
englishstiv
Post by englishstiv »
Yes it fits without any major issues just a bit tighter on the screw fixings, I also have a 906 front fairing with a smoked screen which I have used in the past. and although an after market unit and slightly thinner than the original that also fitted without issue.
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
Witzie
Post by Witzie »
The tank is part of the fairing and its different than that of a 907 , no internal fuel pump
Kawasaki Z700 1987, Kawasaki ZL1000 1990, Ducati PASO 750 1990, Ducati 900ss 1994,
Kawasaki ZZR1100 1993, Ducati Paso 906 1989
Question was will the 906 fairings fit a 907. tank internals do not matter. answer is yes they fit but some of the screws may be tight which will be true just going from one bike to the next
