charge warning light coming on at low RPM
Posted: Sun Jun 30, 2024 2:01 pm
by steved001
92 907ie. No doubt a simple question/answer for this esteemed group, is this an indication of a failing voltage regulator?
Re: charge warning light coming on at low RPM
Posted: Sun Jun 30, 2024 2:02 pm
by steved001
Sometimes flickers, sometimes illuminated continuously.
Posted: Mon Jul 01, 2024 7:40 am
by higgy
it is certainly an indication that you need to look into charging
Posted: Mon Jul 01, 2024 12:49 pm
by steved001
Yup, thanks, I suspected that, just wondering if anyone else has faced the low rpm charge light specifically and if that meant this was indicative of a failing regulator, or problem with the rotor/stator or some other part of the charging system (I'm a former outboard mechanic, and the systems are similar, but in those days few OBs had a charge light).
Posted: Mon Jul 01, 2024 7:53 pm
by Mc tool
Get stuck in with a multi meter , you maybe lucky enough to find a bad earth or connection .
Posted: Tue Jul 02, 2024 8:25 am
by higgy
lots of info here on charging systems
Search found 158 matches: 907ie charging system
Posted: Thu Jul 04, 2024 4:12 pm
by steved001
OK, thanks, plan on poking around with a DMM today.
Posted: Sat Aug 17, 2024 7:57 pm
by steved001
Checked all voltage regulator connections, all were clean and tight. I get voltage increase with rpm increase, at idle it isn't charging, 12.45. Battery is new. At about 2500, it goes to 13.00. I've ordered a new VR. What should the proper voltage be at about 1000 rpm?
Posted: Mon Aug 26, 2024 10:27 pm
by steved001
Completed voltage regulator replacement, required some wiring modifications, I had to make an adapter to go from male bullet to male bullet. Voltage is now back to normal.
