rear shock
rear shock
so what does everyone think about hagon shocks. i need a new shock for my 907,
Re: rear shock
Is the old one past a rebuild ?
Re: rear shock
i believe so, no one rebuilds them do they?
Re: rear shock
Well it depends a bit on which shock you have . If the shaft is ok and its not leaking oil just pulling it to bits and giving it a good clean out and fresh oil can make a difference . There are still some parts available , The seal is probly the most important and I have not yet failed to find something that fits in any of the shocks I have fixed on my own vehicles .
I had a VFR750 and did the re oil , I cunningly used slightly thicker oil ( to allow for internal wear ) than what Id guessed the original stuff to be
so yeah nah , wasn't 30w .... more like 10w .
Depends on how much messing about your into. A new shock sure would be easier.
Have a look in the FAQ's as Im sure this has been come up before now .
Hamish
Hamish
- Thebenelliman
Re: rear shock
My 907ie has a Hagon shock and it handles well and is good value for money
The Benelliman
1992 907ie
1981 Benelli 900 Sei
1976 Benelli 125 Enduro
1981 Benelli 250 2c
1976 Benelli 250 Quattro
1980 Benelli 254
1992 907ie
1981 Benelli 250 2c
1980 Benelli 254
Re: rear shock
Well there you go
I bought budget Hagons for my Guzzi 15 years ago and while not having had much use they don't leak and haven't gone rusty.... yet.
I have a notion that Hagon make shocks to suit a few budget levels .
