Time for a new stator?
Posted: Sat Apr 12, 2025 10:11 pm
The patient - 1988 Paso 750
Last year I noticed the Paso was over charging (16-18 volts DC at the battery). The original regulator/rectifier was replaced with an electrosport esr515. Now the motorcycle is under charging (12.1 volts DC at the battery).
There are three wires coming from the stator - two yellow and one red. When running at 3000 RPM, there's about 30 volts AC coming from each yellow wire and about half a volt coming from the red wire.
Your help is appreciated.
Thank you.
Thank you.
