Front fork travel
Posted: Mon May 19, 2025 3:29 pm
by Giscard
Hi. I have just replaced my tyres, thanks to MC Reifenservice, Alfred Schenk for rhe new Shinko's. While I was at it I did the wheel bearings and thought I would change the fork seals.
All seemed to go OK. At a suggestion, I think on here, I used 7.5W oil instead of the 5.0W oil.
When I got the forks back together I pressed down on the stantion with my full weight and I could get it to compress to about 3cm. At that point it felt solid, so I was not totally happy with it.
Anyway I put the forks back into the bike and eventually took it for a tentative ride. All felt ok on the the roads that were not full of potholes. However I I did go over a fairly deep pothole and it was really uncomfortable through my wrists.
I now have the forks off the bike again. Before I take them apart (and fit new fork seals!) to see if I have put anything in upside down etc has anyone any suggestions. Should I go back to the 5.0W oil, would I expect more than 3cm of travel with me physically compressing the fork.
Re: Front fork travel
Posted: Tue May 20, 2025 7:53 pm
by Giscard
Ok I decided to just drain the oil and change it for 5W to see if that will make them a little softer. I took the spring out and checked the "stroke" and it was close to the 4.9 inches in the manual so all seems ok there. I think I was just surprised at how hard the suspension felt on a road covered in pot holes.
Posted: Tue May 20, 2025 8:11 pm
by Mc tool
Hi , how much fluid did you putin there. If there is to much the forks wont fully compress ' :)
Posted: Wed May 21, 2025 8:52 am
by Giscard
Good point. The amount of oil is the thing that is worrying me slightly. I filled the forks to the recommended 180mm from the top. However, the manual said "perform the oil filling with barrels at end of stroke inside the slidings and without springs and spacers. I took this to mean that the slider was pulled out as far as possible but I am now thinking that the slider should be pushed in as far as possible. Please can someone confirm which it is as I am starting to feel a bit stupid.
Posted: Wed May 21, 2025 9:41 pm
by Mc tool
Measure fluid level with forks compressed and springs and spacers removed . :)
Posted: Thu May 22, 2025 8:06 am
by Giscard
Thanks McTool. You have confirmed what I eventually thought was the problem. When I was adding the oil to the forks that I had extended, I thought this is a lot of oil. It's a pity I didn't stop and reread the instructions. I still think they are ambiguous, but that's down to me. :banghead:
Onward and upward.
Looking forward to a much smoother ride.
Posted: Fri May 23, 2025 8:32 am
by higgy
:banghead: unfortunately in most shop manuals some things are assumed as previous knowledge
Posted: Fri May 23, 2025 9:03 pm
by Mc tool
higgy wrote: ↑Fri May 23, 2025 8:32 am :banghead: unfortunately in most shop manuals some things are assumed as previous knowledge
Gets worse as you get older too , Im surprised at all the knowledge I've forgotten ......or only thought I knew......previously :D :lol:
Posted: Sun May 25, 2025 10:09 am
by Giscard
So true. All my other bikes are from the 50's and 60's. With their fairly basic front forks, it is usually put in a certain amount of oil with no concerns about stantion position. Ah well never too old to make mistakes, and hopefully with advice, to correct them. :lol:
