P7 question
Posted: Thu Feb 02, 2006 1:19 am
by Rlbol
Does any one know which pins of the ECU you would use to read the value of the TPS? All the info I have found on the P7 computer lists two pins, I belve pin 7 and 12. But there is no wire coming out of the ECU for one of those pins? So I am thinking The pin numbers I have are wrong, thanks
Posted: Thu Feb 02, 2006 6:11 am
by Stingray230SX
P7 or P8 ECU: Pins 11 and 17.
this taken from the most excellent FAQ at the ultimap(formerly FIM)eprom-chip maker for the fuel injection systems.
http://www.fuelinmoto.com.au/ <-----this is the main site,then use the links on the main site to find the complete FAQ and read exactly how to adjust the tps
doug hunt
Posted: Thu Feb 02, 2006 8:37 pm
by Rlbol
Thank you very much!
That is what I needed!
