Wanted: Paso Kick Stand Switch
Posted: Sun Feb 01, 2026 5:04 pm
by Pasop750
Mine stopped working (dash light would not come on with kickstand down). Ducati Part # 037012590 is unobtainium. Let me know if you can help me out.
Many thanks!
Re: Wanted: Paso Kick Stand Switch
Posted: Sun Feb 01, 2026 6:58 pm
by Mc tool
This is where one needs to keep his eyes peeled when in motorbike shops .....lookin for modern bits that might fit offa new bikes .....they all have a side stand switch .....maybe one could be fitted to Paso . In any event make sure its the switch and not the bulb or wiring .😁
Posted: Mon Feb 02, 2026 8:36 am
by higgy
:beer: :phone: ditto on the bulb and wiring especially where the dash connectors are concerned
Posted: Mon Feb 02, 2026 11:33 am
by Tamburinifan
+1 on wiring.
Posted: Mon Feb 02, 2026 12:58 pm
by Pasop750
Thanks for the suggestions! I have checked the wiring and the dash light and they are both working. I removed the switch and bench tested it and it is definitely the problem. Unfortunately the switch is a sealed unit (which I found out when attempting to dismantle it) and now it's beyond repair.
Posted: Mon Feb 02, 2026 6:53 pm
by Mc tool
Pasop750 wrote: ↑Mon Feb 02, 2026 12:58 pm Thanks for the suggestions! I have checked the wiring and the dash light and they are both working. I removed the switch and bench tested it and it is definitely the problem. Unfortunately the switch is a sealed unit (which I found out when attempting to dismantle it) and now it's beyond repair.
Ha ha ,often the best way to diagnose problems ....pull it to bits ......well ya gotta be sure😁
Posted: Mon Feb 02, 2026 6:57 pm
by Mc tool
Have a google ,I found some on ebay (used) and new from a couple of places. Google sidestand switch tho , not kickstand
Posted: Sun Feb 15, 2026 7:17 pm
by Pasop750
So a couple of things to update this thread:
1. I found this on Amazon
https://www.amazon.com/dp/B0DF2TP7SQ?re ... asin_title
The stock threads for the OEM kickstand switch are M8 x 1.00 pitch. This switch is M7 x 0.75 so I had to "MacGyver" the mounting (no threads were damaged).
2. In the meantime I managed to fix the broken stock switch so now I have a spare
Bottom line is I am not looking for a stock switch any more!
Posted: Mon Feb 16, 2026 10:25 am
by Tamburinifan
:thumbup:
