Sounds, like Injection adjustments are NOT correct
; but i am not 100% sure.
Adjustments MUST be done this way:
Throttle Position Sensor adjustment.
Butterfly synchronisation.
CO Trimmer setting.
Air Bleeds.
We use the following sequence to correctly align all parts of the induction system. This sequence is essentially the same as the factory recommended sequence:
Set the Throttle Position Sensor on the throttle shaft. To correctly do this you must:
Completely back off the idle stop screws on both throttle bodies.
Use the Mathesis tester or a Digital MilliVoltMeter to read the throttle sensor voltage. To do this you should tap the butterfly with your finger to ensure that the butterfly is completely closed against the body. Then you turn on the ignition and measure the voltage on the throttle sensor:
P7 or P8 ECU(907IE!!!): Pins 11 and 17.
If the sensor does not read 150mV Plus or Minus 2mV then you need to adjust it:
Slacken the lock screws on the throttle sensor using a screwdriver or 7mm socket.
Carefully move the sensor whilst reading the voltage.
Retighten the lock screws a little at a time, each time reading the voltage and adjusting the sensor.
Note that you should probaly overshoot the reading by about 5mV on slack screws, because when you tighten them the reading will change by about 5mV.
Repeat until perfect. This takes a lot of practice.
The factory manuals specify +/- 5mV but we feel that this is not accurate enough. many owners will attest to the difference in performance when the sensor is set perfectly.
Re-set the throttle stop screw (or screws) so that the engine idles at around 1200 rpm. This is not a final setting for the stop screws, merely a step in the procedure. Typically this will produce a voltage of around 300mV on the TPS. This value is completely arbitrary and is not important. Many people misunderstand the factory manual in this regard and will try resetting the TPS until they get 1200 rpm idle and exactly 300mV on the sensor. THIS IS WRONG !!!. The actual voltage on the sensor at idle is irrelevant to correct sensor positioning on the throttle shaft. Trust Me !!
Synchronise the Butterflies:
Close the airbleed screws completely by adjusting CLOCKWISE. If you don't do this then the throttle vacuum will still reflect any air passing through the bleed channels and the butterflies will not be perfectly synched.
Attach vacuum guages to the manifold port on each cylinder and run the engine.
Adjust the throttle butterfly link shaft until vacuum is identical.
Rev the engine and confirm that vacuum tracks on both cylinders throughout the throttle and RPM range.
Re-adjust the link shaft until satisfactory results are obtained.
Do Not adjust the throttle link shaft after this point.!!
Set the IDLE Balance by adjusting the airbleed screws counterclockwise and confirming that the vacuum is identical for both cylinders at idle. You can rev the engine and observe vacuum tracking through the rev range, and then observe idle vacuum restabilising. NOTE Since the airbleeds are designed to iron out any irregularities in the throttle's function, by their nature there is no default setting, unlike the idle screws on a carburettor. If anything the default setting is fully closed. Airbleeds can also be balanced using a 2 channel CO meter. In this case, just adjust the bleeds until both cylinders have the same CO.
Adjust the IDLE Mixture. Finally you get to set the CO Trimmer ! This will affect both cylinders by the same amount, so you need to set the airbleeds first. A typical CO figure for idle is 4% to 6%, but automotive regulations usually specify a CO of under 1% to meet emmissions standards. A V-twin will idle very poorly if the CO is set below 1%, so if you are really bothered try a setting of about 3%. Note that you may need to finesse the airbleeds at this stage.
Adjust the IDLE RPM. Set the idle rpm at the manufacturer's figure (usually 1100 - 1200 rpm) by adjusting the throttle butterfly stop screw (or screws). We recommend 1200 rpm for Ducatis and Guzzis, possibly 1500 rpm for Ducati 996SPS models.
Finally, note that the last three steps are usually repeated until an acceptable balance of Idle Balance, Idle Mixture, and Idle RPM are obtained. This is normal. Do Not adjust the throttle synchronisation link shaft once it is set in the early stages. If you do this now, you will need to go through the entire sequence again.
So hopefully you will have an engine which now idles, accelerates, and delivers full power faultlessly. Again, if you are not confident about all of these steps, then we suggest you use a dealer who has the skills and equipment. It is not worth adjusting the CO trimmer unless the entire sequence is followed without skipping any steps.
Btw, WHAT kind of CRC You put to injection system???
Those injectors are very sensitive eqipments, so its good to take them every 40 000-50 000 km to such injection maintainer, who clean and check them totally, how they spray fuel. There is also special filters in input hole of injector and those maintainers change those filters with SPECIAL tool. I know, that there are many kind CRCs, but i dont know, have they injection cleaning stuff, or did You put some "normal thin lubrication" CRC? I never put that kind to injection :thumbdown:
