front end shake!!!
Posted: Thu Mar 02, 2006 5:47 pm
by pasophist
1988 Paso 750.
I am getting bad steering wobble at higher speeds. Increasing above 55 MPH. Getting worse with time. I can't find the problem. Any ideas? Rebuilt forks, new micheline radials, straight rotors, no play in steering head- or off centre "fall" when suspended in garage.
Please copy reply to smseigel@shaw.ca
Thanks...
Pasophist-
Posted: Thu Mar 02, 2006 5:56 pm
by jcslocum
Sounds like you need to have the suspension set up properly. What you describe sounds like head shake, the entry into a tank slapper. Have you raised the rear ride or lowered the front height lately?
My Paso will only shake if I let go of that bars at 55. It's slight but it's there.
Posted: Thu Mar 02, 2006 6:30 pm
by pasophist
Thanks Jon:
I have adjusted the rear height somewhat, but I don't really know what I am doing. My goal was to soften it up a bit. I'm new to the bike and it seemed to have been adjusted for a heavier rider.
How does one go about adjusting front suspension height- and should the front or back go up or down to address my problem?
SMS (Pasophist)
Posted: Sun Mar 19, 2006 4:27 am
by davidhughrose
Is your fork overly stiff? If so here's something to look into. I had wobble problems with mine quite a few years ago. My problem boiled down to a dampening (damping?) tube in the right fork leg that was upside down. I checked my manual and there's no exploded diagram and my memory's vague (I did this around 1990), but as I recall the tube was aluminum, something like 10 inches long and about 3/4" diameter. It is a constant diameter. It has holes on one end and not the other, is reversible, and as I recall the bottom bolt in the fork bolts into it. When I flipped this tube upside down it was like magic, curing the wobbling and dramatically improving the handling. If you can find an exploded diagram of the right fork tube & post it I'll identify the piece. Either way, check it out & report back.
Dave
Posted: Sun Mar 19, 2006 4:55 am
by pasophist
Thanks Dave;
Good idea. If I am not mistaken, the shake may have begun after a fork service. My local ex Duc shop did seals and oil and checked out the fork while it was apart. I will investigate.
SMS
